92 blazer oil pump
Old Aug 2, 2010 | 07:01 PM
Zrhighfield's Avatar
Zrhighfield is on a distinguished road
Default 92 blazer oil pump
i have a 92 blazer with a bad oil pump. i was wondering if anyone had any need to know info before i riped into it or any kind of tips or adivce to make this go smoother? thanks -Zack
Old Aug 2, 2010 | 11:39 PM
fondo's Avatar
fondo has a little shameless behavior in the past
How have you determined that you have a bad oil pump? Are you just going by the reading your dash gauge is giving you? Not to come across as a dick responding to your 1st post but you are like the 3rd or 4th person I've seen just this month on this board who has complained about their oil pump being bad.
How many miles on the engine? Have you had an oil pressure master gauge hooked up to the engine and noted oil psi at different engine rpms. As I've learned being a member of this forum, anywhere from 10-25 psi @idle is an acceptable range with for motors.
Let us know...
Old Aug 3, 2010 | 12:01 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Agreed. You'd be surprised by the guys who think they have a bad pump and it turns out it was their sender with a leak which transmits a lower O/P reading. Check this first. It's a heck of a lot cheaper.
Old Aug 4, 2010 | 10:34 AM
the pump is bad there is no oil pressure the only reason its my first post is because im a ford guy and spend my time workin on them the blazer is actully a friends and we have changed the oil sender and what not. so i just wanna kno if anyone has any hints i already have the new pump
Old Aug 4, 2010 | 11:38 PM
old skool luvr's Avatar
well.....since you're convinced the pump is bad...........but i'm guessing you've verified that with a good mechanical gauge.
just be careful you don't drop the driveshaft for the distributor. usually it's held in with a plastic retainer clip (to the top of the pump shaft), but sometimes it becomes britle with age.
just be thankful that your buddy doesn't have a '96+ 4.3 to do this on. you'd be pulling the engine otherwise.
oh yeah.......zero pressure usually means means wiped mains.
Old Aug 7, 2010 | 09:17 PM
There is a check valve (ball) that can stick oprn in the adapter. I'd try about anything before I started pulling the motor apart. Just a suggestion.
BouncingRadical
14
Nov 27, 2015 12:30 AM
RodneyB
Jul 23, 2015 09:48 PM
lowgear
Jul 11, 2015 05:30 PM
todaresqSL2
Nov 10, 2008 01:47 PM
Custis
Jul 11, 2007 07:48 AM
