93 back window squeak
I haven't actually located the precise point the noise is coming from, but I thought I would throw it out to others that may know what part actually causes squeaking from the back window. I know that it is a prevalent problem in Blazers, so if anyone knows what usually squeaks and how it can be fixed (or at least quieted), I'd love to hear about it. I will probably do some more research on my truck to see if it can be more precisely pinpointed.
Hey guys theres a simple fix for that...
I had the same problem and was able to fix it in a few minutes... Is what you need to do is wipe down the rubber weather stripping around the window and the rubber stopper if you have a tire rack on back... Use something that will make the rubber more plyable... If I remember right I think I used baby oil. Also oil up the latch that locks in the rear tire rack.
Hope this helps...
Bryan
Hope this helps...
Bryan
WickedBlazer
Sep 12, 2012 03:14 AM
babeba67
Nov 17, 2011 09:35 AM
