93 blazer front end popping noise.
Old Nov 21, 2010 | 01:24 AM
  #21
junbug's Avatar
junbug is on a distinguished road
my 2001 blazer does that and changes when in 4x4 what is it i replaced ball joints idler arm and got front shoks but no luck
Old Nov 21, 2010 | 07:22 PM
  #22
bam_9_9_9's Avatar
bam_9_9_9 is on a distinguished road
its the torsion bar crossmember mounts. on both sides. i think the mounts are about 20 bucks for 1. i would replace both. what your looking for is the long bars going from the bottom A arm to about the middle of the truck that goes into a crosmember into what are called torsion keys with one bolt holding the keys up. the mounts are what holds the crossmember to the frame.
Old Nov 22, 2010 | 10:54 PM
  #23
AuburnBlazer's Avatar
AuburnBlazer is on a distinguished road
tie rods and idler and pitman arms wont fix it, have you checked power steering box
Old Dec 18, 2010 | 11:59 AM
  #24
Recon's Avatar
Recon is on a distinguished road
I'm having the same problem with my 93 blazer 4dr 4x4, glad I came across this post.
Old Dec 28, 2010 | 07:58 PM
  #25
drtyblnd's Avatar
drtyblnd is an unknown quantity at this point
her is what i think is most probably the culpret. i had a similar problen when i first got my 91. i looked it over up and down took it to shops for pro advice no one could tell me where that dammm noise was comming from i thought it was in the front end too i replaced everything from ball joints ,a arms , cv idler any thing that had to do with th front end i replaced it . it was whene i got all my parts together for the a arms and ball joints did i find the source of the dammmmmmmmm noise i released the tension from my torsion and ill be dammmmmmed if that torsion cross member diidnt fall to the ground all tha $$$$$$$ for a ****y design flaw by gm the only thing holding this this thing is a rubber boot on each side (note your fuel lines run the inside rail and could be dammaged if not attended too) scoured junk yards three citys away could not find one that wasnt damaged but worry not if you look to the earlier years you will find that they are direct bolt, frame to cross member it takes a little work and drilling but it bolts up reinstall torsion bars and youl never here that dammmmmm noise again. the best way to check for this problem is crawl underneath with a good size pry bar an try to pry the cross member from the frame you will notice emediatly good luck and i hope i have solved your delema
special note;; this is a very dangeres proceedure. extrem caution should be exersized at all times. you should not substitute cheap tools to perform this task!!!!!!!!!!!
Markolc
Mar 21, 2015 06:15 PM
mjink.11
Mar 18, 2013 10:32 AM
sschuler
Jan 5, 2009 03:43 AM
bigt7088
Mar 19, 2008 08:00 PM
bob the blazer
Suspension Tech
Jun 16, 2006 10:13 PM
