'93 blazer oil drain plug location
Old May 3, 2008 | 05:07 PM
gooder's Avatar
gooder is an unknown quantity at this point
Default '93 blazer oil drain plug location
93 blazer S10 4x4
Stupid question but it is not as obvious as I thought- where is the oil drain plug located? Should it have a bolt that needs a wrench or an allen-key head that's a bit closer to the rear.
Thanks,
Old May 3, 2008 | 06:59 PM
Default RE: '93 blazer oil drain plug location
Engine oil drain plug will be located in the lowest portion of the sheet metal oil pan and will be a hex head bolt requiring a wrench. It is possible that you have a skid sheild obstructing your veiw of the bottom of the motor.
Old May 4, 2008 | 02:20 PM
gooder's Avatar
Thank you Sir! it indeed was hidden by a skid shield.
Old May 4, 2008 | 04:10 PM
No problem. That's what we're here for!
sasquatchfound
May 15, 2008 03:55 PM
boulonman
Mar 5, 2007 05:10 AM
MCas86
May 11, 2006 07:40 PM
eng69
Feb 13, 2006 03:08 AM
2001Blazer4x4
Mar 2, 2005 10:45 PM
