93 Chevy Blazer S10
Old Feb 24, 2008 | 05:37 PM
countryguy1713's Avatar
countryguy1713 is an unknown quantity at this point
Default 93 Chevy Blazer S10
I am trying to get the windshield washer hose connected the the place where it sprays out to hit the windshield but in order to do that i need to remove the piece right at the bottom of the windshield but i cant do that without removing the windshield wipers...Any ideas on how to remove them?
Old Feb 24, 2008 | 06:22 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: 93 Chevy Blazer S10
dont quote me as being poistive about this since i have a 2002 at the tip of the wiper arm where it mounts one there sumtimes is a clip that ya slide out with a screwdriver and it releases the arm...try that..
Old Feb 24, 2008 | 08:24 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
head to auto zone, NAPA or someplace like that. You'll be helped by a special tool you can borrow or I'm sure buy at $10 or so. It'll be a big help as the wiper arm on a s type blazer was the same(needing this tool) from 1983 to 1994. later jp ps I'm sure there are other ways to get it off but.....[8D]
Old Feb 25, 2008 | 07:29 PM
Dog's Avatar
Dog
Dog is an unknown quantity at this point
I have an '88 - I'll assume yours works the same way.
At the base of the wiper arm just short of where it forms the circular base that mounts to the wiper motor pivot (or, roughly where the arm hinges) you should notice 2 small holes; one on the top surface and one on the bottom surface of the arm, directly opposite each other.
If you pull the arm away from the windshield, use a thin finishing nail or something similar and prop the wiper away from the glass by inserting the nail thru the two holes, and release the wiper so that the nail keeps the wiper from contacting the glass. This proces releases tension on the base, and should allow you to simply pull the wiper assembly off of the pivot.
If your wiper arm doesn't have the two small holes, then I am of no help...
Old Mar 1, 2008 | 05:11 PM
Hanr3's Avatar
Look at the base of the wiper arm, it has a plastic cover. pull the cover off and under it is a nut. Take the nut off and the wiper arm comes off.
Now that you found the nut, if you strip out your wiper arm, as in it wont move when teh other arm does. Pull hte arm off, clean out all the metal shavings, put the arm back on and tighten the nut down again. The inside is lead type metal, soft metal and designed to give if your blade gets frozen to the window or stops moving for some reason. Simple fix if your in the middle of nowhere in the middle of a horrible storm. Just need a pair of pliers or adjustable wrench.
Old Mar 1, 2008 | 05:22 PM
thegr81's Avatar
ORIGINAL: Hanr3
Was going to say the same thing you beat me to it!!
ChevyMane808
Apr 5, 2013 10:51 AM
Joetrillhours
Feb 9, 2008 12:43 PM
celchlepp
Jan 10, 2008 01:24 AM
jesseb
Oct 16, 2007 02:34 PM
pandabaer
Oct 25, 2005 01:22 AM
