'93 GMC jimmy clunking/slapping sound
Old Dec 19, 2011 | 01:06 PM
richphotos's Avatar
Default '93 GMC jimmy clunking/slapping sound
I put this in the suspension tech thread, but no response. Figured I would put it in the first gen section too. If this is not ok to have in 2 places, Please remove the one from the suspension tech. Thanks!
Ok, I had this same problem on my 94 s10 blazer when I had it, drove it with the noise for a year before it was totaled. But, it REALLY drives me nuts, and this seems like the place to ask for help.
Ok, mostly when turning left while going over bumps (ever so slightly when going right), I hear a clunking/slapping sound, if I go below 10mph I do not hear it, has to be some momentum behind it to make the noise, It comes from the passenger side only. So I got into the mode to listen to it, and tried to figure out where it was coming from, so I rode in the passenger seat and had someone drive, I could feel it in my feet, but it was really hard to pinpoint what location it was coming from, at times it sounded like it was closer to the floor board, but it also sounded like it was coming from the base of the windshield area by the cowl, I am baffled and rather annoyed by it.
Checked the ball joints, they are not even 2 years old, boots are in good shape, inner and outer tie rods are in good shape as well. Sway bar bushings, control arm bushings were all replaced when the ball joints and tie rods not even 2 years ago.
I was reading up and found a few things it could be but I honestly do not know, torsion bar mount, loose shock bolt, or even the hood hinge, apparently GM did not install a washer causing the hood to clunk (but if it was the hood hinge, I would think it would do it over all bumps, and not just when turning left)
Sorry for my long winded description. hope someone can help.
Thanks
Old Dec 19, 2011 | 01:10 PM
Please have a read through the rules of the forum. Double posting is covered.
*Thread Closed* If you wish to have a thread moved to what you may feel is a more relevant section, you can post that in the thread in question. I will move your previous thread to this section. And please have patience. No one here is paid to respond. If you haven't received a response after waiting at least 24 hours, then you can 'bump' your post. Please do not create another thread in another section.
richphotos
Dec 24, 2011 02:43 PM
GregM
May 29, 2011 03:41 PM
musclecar70sfan
Nov 7, 2010 08:48 PM
londonmazda
Oct 19, 2010 02:15 AM
tankie88
18
Jan 27, 2006 05:33 PM
