93 s10 blazer 4x4
Old Jul 25, 2010 | 04:47 PM
mao1848's Avatar
mao1848 is on a distinguished road
Default 93 s10 blazer 4x4
i have 93 s10 blazer that has power going to the switch in the dash. its electronic. but it will not light up when i hit it to engage into 4 wheel. nothing happens and no noises are heard. the switch seems to be working fine because electricity is flowing through and you can get the lights to work if you just check the switch with power. wondering what it could be. it use to work a week ago but it just stopped.
any ideas. it would be helpful thanks
Old Jul 26, 2010 | 07:08 PM
TandJ's Avatar
TandJ is on a distinguished road
been having the same kind of problem with my 93 jimmy. found a link in here that really helped me out. it seems that the common problem is with the vacuum accuater (located under the battery tray) or its lines. if you do a search on the front axles not engaging there is a lot of help here. good luck
Old Jul 26, 2010 | 09:07 PM
mao1848's Avatar
thank you. i will try this and see if it helps.
Old Jul 26, 2010 | 09:12 PM
*Moved to 1st Gen Tech* - Forum Help & Suggestions is for help relating to the use of the forum and/or suggestions for possible additions/etc.
Check out the Tech Article (DIY) section for some informative 4wd threads and see how they help.
Old Jul 27, 2010 | 01:18 AM
mosfetpioneer's Avatar
mosfetpioneer is an unknown quantity at this point
Dallas1970
Feb 22, 2019 05:05 PM
94BlazerGirl
Aug 28, 2014 06:14 PM
rfine67
Aug 13, 2011 01:04 PM
RickBlazer
Jun 23, 2011 04:59 AM
ricky
Jul 22, 2010 08:04 PM
