93 s10 blazer blend door actuator
Old Aug 25, 2019 | 03:37 PM
Gnd's Avatar
Gnd
Gnd is on a distinguished road
Default 93 s10 blazer blend door actuator
Hi I am having trouble with my AC system on my 93 S10 blazer. I am have a problem with my AC is only blowing out the bottom vents and defroster vents. So I’m trying to locate my blend door actuator but I don’t know where it is
Old Aug 26, 2019 | 12:35 AM
I'm not familiar with the 1st gens but in the 2nd gens, if the problem is from where the air is blowing, it is more likely a vacuum leak in the hoses that supply vacuum to the actuators that direct the air in the under-dash plenum.
Again, in the 2nd gens, if the issue is you cannot change the heat, whether in AC or non-AC mode, then it is the electronic blend-door actuator. (These fail by the axle in the electronic module slipping when the gear in them cracks.)
Old Aug 26, 2019 | 10:06 PM
Gnd's Avatar
Gnd
How would I find a vacuum leak
Old Aug 27, 2019 | 10:02 AM
rriddle3's Avatar
*The section "Website Problems and Suggestions" is for reporting problems with the website, as the name implies. This thread has been moved to the correct section, "1st Gen Tech".*
BlazerUT
Jul 17, 2018 06:53 PM
Nixoncc
Nov 13, 2017 09:49 AM
02blazs10
Apr 6, 2013 02:50 PM
c0a8l0v6i8n9
Dec 12, 2011 10:42 AM
shredyou
Sep 5, 2011 01:10 AM
