93 s10 does not start or idle
Old Sep 26, 2009 | 04:56 PM
Vector's Avatar
Vector is on a distinguished road
Question 93 s10 does not start or idle
My buddy has a 1993 chevy s10. It will not start on its own, but if you prime it, then it will start. It also will not idle, so you must keep giving it gas to keep it running.
He replaced the ECU, and checked to make sure that it was getting gas to the carburettor when attempting to start, which it is. I think that he also said that it was getting voltage. Someone else said that it might be a crank sensor (whatever that means). Do any of you have any ideas?
Thanx
Old Sep 26, 2009 | 07:52 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Sounds like the fuel pump doesn't put out enough pressure for it to start. If you prime it and it will start, the pump is the prime suspect.
A '93 doesn't have a carb. Does he have a TBI or a CPI? Has he checked the fuel pressure?
Old Sep 26, 2009 | 08:01 PM
Vector's Avatar
He says it is TBI. He didn't check his fuel pressure yet. I probably should mention that this is a s10 pickup and not a blazer; but i don't there there is a difference under the hood. The engine is a 2.8 liter.
Old Sep 26, 2009 | 08:07 PM
Easiest thing to do first is change the fuel filter - it could be clogged, allowing some fuel through but not enough under load.
Old Sep 29, 2009 | 12:10 PM
Vector's Avatar
He said that he recently change his fuel pump and filter....... sorry.......
Old Oct 1, 2009 | 01:24 AM
Hanr3's Avatar
Recently, as in after he replaced them he started having problems recently. Or he replaced them and everything worked great for a while until this problem started?
Verify the fuel filter is face the right direction? there is a forward and backward on em.
My next thought is the IAC, it controls idle. Sensor on the TBI unit.
Old Oct 1, 2009 | 01:11 PM
Vector's Avatar
He said that it was having this problem before he replaced them, and that the problem was the reason why he tried replacing them. I told him what you said about the IAC and TBI.
Thanx
TrainChaser22
Dec 4, 2019 12:27 PM
Amelia23
Sep 29, 2012 05:31 PM
blazerJim1701
Jul 26, 2009 09:18 PM
jspafford
Jun 10, 2009 04:51 PM
