94 4x4 issues
Old Jan 21, 2010 | 01:33 PM
Litehwk356's Avatar
Litehwk356 is on a distinguished road
Default 94 4x4 issues
i have a 94 s10 blazer 4x4, and im having problems with my 4 wheel drive.
what happens is that i will go into neutral, and press the switch, sometimes it will engage into 4 wheel, sometimes it wont, then when i want to come out, the same thing happens, sometimes it comes out ok, sometimes it wont. what should i be looking for? im a ford guy myself so im not sure about these gm vacuum 4x4 systems. thanks!
Old Jan 21, 2010 | 07:55 PM
Could be a connection problem to the TCCM. Could be an intermittent encoder fault.
I would inspect all of the electrical connections from the switch to the TCCM to the encoder motor on the side of the transfer case.
Old Jan 21, 2010 | 09:05 PM
Eff10's Avatar
Eff10 is on a distinguished road
I am having a very similar problem, only my 4 hi wont engage at all and the 4 lo will sometimes and then not come out of it. Hopefully we can come to a conclusion together. Some of the guys told me to check the vacuum lines and make sure nothing is loose, and someone else mentioned to check behind the button if its a push button because sometimes the contacts get dirty and mess up the controls. Hopefully for both of us it's something easy and not expensive. I'll let you know if I figure it out.
Old Jan 23, 2010 | 06:10 PM
Drifter666's Avatar
Drifter666 is an unknown quantity at this point
im sorry lite but i cant help with yours but eff10 my 94 was doing the same thing, i went to the junkyard and got a new push button switch and it cleared it right up. I am currently having a problem with mine now also if i may ask it here "i dont want to hijack the thread" but my 4wd switch will only blink both lights no matter if i try to go into 4Hi or 4Lo and sometimes it wont even do anything like it doesn't have power would either of you guys have any ideas?
Old Jan 23, 2010 | 09:09 PM
Eff10's Avatar
I found the answer to my 4x4 problems with this thread https://blazerforum.com/forum/tech-articles-diy-29/4x4-no-worky-maybe-will-help-7180/
It's easier for you to just read it than for me to explain it to you.
daemeon2
Jan 6, 2013 04:06 PM
99slobra
Jan 3, 2013 05:02 PM
cruukedeye
Jun 4, 2011 06:49 PM
BaLListic_Evo
Jun 4, 2010 03:38 PM
cmh_20
Nov 21, 2009 11:39 AM
