94 Blazer dies randomly
Old Apr 18, 2011 | 09:10 AM
96BLAZE's Avatar
96BLAZE is on a distinguished road
Default 94 Blazer dies randomly
My buddy has a 94 Blazer S10 Tahoe 4dr 4x4 with the 4.3L Vortec. His truck NEVER starts on the first try. The second try he has to pump the gas which is weird because it is fuel injected. Also, his truck like stalls out randomly when he is driving. He has 2 holes in his catalytic converter. Could that cause the truck to have trouble starting and die? Thanks in advance.
Old Apr 18, 2011 | 08:46 PM
jmd8074's Avatar
jmd8074 is on a distinguished road
I would start by cleaning the throttle body including the iac motor and ports. make sure air filter is good and there are no vac leaks downstream of the MAF sensor
Old Apr 19, 2011 | 08:49 AM
96BLAZE's Avatar
well yesterday i read about a blazer that had a clogged exhaust and his truck would die so i was wondering if maybe something got in his exhaust from the holes?
Old Apr 19, 2011 | 05:01 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
The two wires that go to the spider injector , I have the same blazer and it took me a while to figure it out . I guess they are pretty common to failure . The wires go into the front of the engine just give them a wiggle the next time its acting up and if it helps then you know .
Old Apr 20, 2011 | 08:53 AM
96BLAZE's Avatar
thanks, definitely will try that.
where is the input from the admins? lol
Old Apr 20, 2011 | 12:51 PM
roppelt's Avatar
roppelt is on a distinguished road
and don't forget to check the main computer, I had the same problem... mine kept dying... I kept getting a o2 code, replaced the o2 sensor the pvc valve and the spider,still the blazer kept stopping. I finely had to replace the computer. very expensive to do all that work.
Old Apr 20, 2011 | 08:57 PM
94BlazerPA's Avatar
94BlazerPA is on a distinguished road
Could also be a fuel pressure issue. Check your fuel pressure, should be around 60 psi. The fuel regulator could be going bad and not giving you the fuel pressure needed to start the on the first try. So you need to cycle your pump twice to get the pressure up, so it can start. Alot of people will say its your spider, but its not, it the fuel regulator attached to the spider. Check your fuel pressure and let us know what your working with.
Old Apr 21, 2011 | 08:36 AM
96BLAZE's Avatar
thanks a lot for the suggestions. how would we go about checking the pressure?
Old Apr 26, 2011 | 09:42 AM
96BLAZE's Avatar
ok so my buddy says that the fuel pressure is fine. and i forgot to tell you guys that he doesn't know how many miles are on the motor. it says 90k but it stopped working before he bought the truck. from reading other threads, it kinda sounds like the fuel pump. also could clean the EGR. could it be electrical? please post any suggestions.
-thanks
tinyejp
Oct 29, 2012 01:41 PM
Jetpack_Ahoy
Aug 16, 2012 09:15 PM
fatguy605
Jul 14, 2011 04:13 PM
ragainff
May 30, 2011 08:38 PM
Talusgirl
Apr 21, 2011 06:05 PM
