94 Blazer- Heavy brake pedal, rough idle
Old Oct 20, 2007 | 06:19 PM
speedingpenguin's Avatar
speedingpenguin is an unknown quantity at this point
Default 94 Blazer- Heavy brake pedal, rough idle
So I origionally thought that it was the fuel pressure regulator that was causing the rough idle, well now its got a real heavy brake pedal and an even rougher idle, I'm guessing the brake booster is at fault for at least part of this?
Pump the brakes with the engine off and start it up, the pedal does go down a little bit, with the engine running theres pleanty of vacuum from the check valve, sound like the brake booster then?
Old Oct 20, 2007 | 06:28 PM
thegr81's Avatar
Default RE: 94 Blazer- Heavy brake pedal, rough idle
yes it does if the brake pedal gets really hard then its the booster
Old Oct 20, 2007 | 08:08 PM
BigGreenMonster's Avatar
BigGreenMonster is an unknown quantity at this point
Yeah, I'd say the diaphragm on the booster is shot. Do the master cylinder while you're at it.
Old Oct 20, 2007 | 08:14 PM
thegr81's Avatar
i agree do the master cylinder at the same time consider it preventive maintenance
Old Oct 24, 2007 | 12:29 PM
Hanr3's Avatar
before you do that, verify the vacuum hose from the engine to the brakes isn't leaking, and is still connected. [8D]
Old Oct 25, 2007 | 02:17 AM
Chevy Lover's Avatar
I agree with Hanr3, check the vacuum hose first. Also plug the vacuum hose, run the engineand see if the idle smooths out.
I'd only replace the master cylinder if it was leaking out the back into the booster and you should be able to see that when you pull the master cylinder forward, before disconnecting the brake lines.
zach bjorge
Mar 17, 2011 06:49 PM
Imperator
Mar 17, 2010 08:47 PM
comart45
Feb 25, 2010 10:05 PM
Kendo
Sep 24, 2009 01:12 AM
Moto_Quetzy
Jun 30, 2007 04:54 PM
