heavy gas pedal
Old Mar 17, 2010 | 04:16 PM
Imperator's Avatar
Imperator is on a distinguished road
Default heavy gas pedal
Hey, the gas pedal on my 1980 K5 feels really heavy (or tight).
You have to push really hard to accellerate. Since i can't pick up the car until the 27st of this month i can't take a look at it.
Could it be a spring issue?? Are there more options for the problem??
Thanks
Chris
Old Mar 17, 2010 | 06:23 PM
Sounds like someone has put too strong of a spring on the carb linkage. Be careful though, this could have been done because of a sticking carb. You'll want to check things out thoroughly to make sure that the throttle doesn't hang wide open on you and cause GM to be in the same boat as Toyota (jokingly of course)!!
Old Mar 17, 2010 | 07:10 PM
abig84's Avatar
My k30 is the same way due to above reason. I have 2 springs on it. With only one it idles at like 1400. Spray everything that moves with lube and check out your spring situation
Old Mar 17, 2010 | 08:47 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
HAHA good one kyle!
NYCJUDGE
Aug 28, 2011 04:35 PM
speedingpenguin
Oct 25, 2007 02:17 AM
Moto_Quetzy
Jun 30, 2007 04:54 PM
drperry
Performance & Brainstorming
Apr 26, 2007 08:48 PM
nofear17bmx
Dec 31, 2006 09:45 PM
