94 Blazer issues. Please help!
Old Jan 3, 2009 | 10:07 PM
rwhittmore's Avatar
rwhittmore is an unknown quantity at this point
Default RE: 94 Blazer issues. Please help!
when i had the plenum off there were no clean spots around the injectors or anything. its really becoming more trouble than its worth lol. the spider injector wasn't leaking, the fuel pressure regulator is new, it runs fine at idle and the only time it acts up is when your giving it full throttle, it just seems to hold steady at about 3000 rpm and starts popping and spitting. is it a possibility that the fuel pump is just wore out? i'm not sure if that would cause it to bleed down or not. or is it a possibility that the spider is somehow bleeding down internally and letting fuel pass through the return line? i'm not too familiar with these engines and i just want to be sure before i cough up 230 bucks ona new injector unit. i might head to the junkyard tomorrowto pick up a couple of them to see if that might fix the problem. if so then i might spend the extra cash to get a new one.
HelpWitBlazerPLZ
Feb 15, 2011 11:48 PM
02chevyblaze
Dec 1, 2010 11:06 PM
wally72909
Dec 10, 2009 09:13 PM
rogggg1020
Nov 11, 2008 08:05 AM
wildcatxcr8
Jun 23, 2006 09:36 PM
