94 Blazer Knocking Sometimes
Old Jul 31, 2009 | 04:11 PM
twellis007's Avatar
twellis007 is on a distinguished road
Default 94 Blazer Knocking Sometimes
I have a 94 Blazer, 4.3 Vortec 4wd. It is a work truck. The engine started knocking and loosing power so I put another used engine in it. It ran fine for about 6 months then started to knock. It doesn't do it all the time. Sometimes when I crank it up it runs fine with plenty of power. At other times it will knock terribly and have a hard time getting it to change into overdrive. This may happen several times a day going between knocking and running fine. Does anyone know what might cause this?
Old Jul 31, 2009 | 07:38 PM
Does it sound like a bottom end problem or more a top end ping problem? The fact that it comes and goes makes me think that it is related to either fuel supply or ignition timing.
Old Aug 3, 2009 | 07:13 PM
twellis007's Avatar
Been researching this and it seems to be related to the counter-balance shaft that comes in this particular engine. It is also a possibility that the timing chain has too much slack in it allowing it to jump timing at times which would account for the difference in idle speed. I am taking it off the road this week and pulling down the front of the engine to see if this is the problem.
Eric S
Mar 18, 2012 07:12 AM
novaman66
Mar 21, 2011 08:19 PM
byrm31
Dec 7, 2010 08:29 PM
Sarahsmith854
Jul 19, 2007 09:03 PM
tcitjh
Jan 29, 2007 07:10 PM
