'94 Blazer Spits & Sputters
Old Jun 16, 2011 | 10:01 PM
chevy4.3vortec's Avatar
chevy4.3vortec is on a distinguished road
Default '94 Blazer Spits & Sputters
hi i have a 94 S10 blazer thaoe LT 4.3L vortec and it runs like crap. it spits and sputter when idling and acelerating and when you first start it, it idles reall low to where it feels and sounds like it going to stall. can any one help please.
Old Jun 16, 2011 | 10:32 PM
rriddle3's Avatar
*Moved to '1st Gen Tech'*
Old Jun 20, 2011 | 06:37 PM
ely0569's Avatar
ely0569 is on a distinguished road
Could be a number of things.....Is your check engine light on?
Old Jun 20, 2011 | 08:12 PM
ohsofly's Avatar
Probably another spider problem... Do a search on CPI INJECTOR for troubleshooting info... The easiest way to tell is check your oil level, if you are leaking fuel it will be overfull...
Old Jun 21, 2011 | 09:03 AM
chevy4.3's Avatar
Banned
chevy4.3 is on a distinguished road
the check engine light at first didnt come on untill i was sitting at a stop for over a minute and the codes that were displayed were ignition control error and map sensor low sig. and egr valve error. and the oil looks like two quarts over filled and not onehundred percent sure if it smelled like fuel or not. then i checked the spark plugs and there fouled and i could take them out by hand ( they were loose before i even touched them).
Old Jun 21, 2011 | 10:35 AM
rriddle3's Avatar
chevy4.3vortec,
As stated very clearly in the Forum rules, creating more than one user account is prohibited. I have removed your account under the name chevy4.3. If you have not bothered to take the time to read the rules, I suggest you do so now.
Old Aug 29, 2011 | 09:45 AM
nswoodsman's Avatar
nswoodsman is on a distinguished road
I had the same trouble, but replaced the fuel pump and cleaned the egr valve and it cleared up. You may also want to look at the router and distributor cap.
Good luck!
JohnBarJB
Sep 28, 2020 07:34 PM
95blzer95
Jul 9, 2014 05:37 AM
Aanenson
Feb 1, 2012 11:00 AM
SlickBlazer
May 25, 2011 07:48 AM
kona1
Jun 14, 2009 07:04 PM
