94 gmc jimmy intermittent sputtering
Old Dec 12, 2012 | 08:36 AM
Silverone858's Avatar
Silverone858 is on a distinguished road
Default 94 gmc jimmy intermittent sputtering
Hey guys great site! I'm glad I found it!
I'm having an issue with my jimmy sputtering randomly and it doesn't seem to have any rhyme or reason to it. I thought sure thing its the spider so I changed it and the nut kit but it made no difference at all, the fuel pump is a gm about 4 years old. Now I'm thinking it's a spark issue, when it's at its worst I get a burning smell which I'm thinking is unused gas getting to the cat.
Btw its a 94 gmc jimmy s15 W vin 4x4 vortec 95000 miles.
Thanks in advance for any help!
Old Dec 12, 2012 | 02:49 PM
More info: parts changed recently
Spider and nut kit
fuel filter
Coil
plug wires
the problem began in August and is steadily getting worse. Shooting from the hip I have changed these parts trying to isolate the problem. The spider change gave no change and the coil and wires made the truck run much smoother but the problem is still there.
This weekend I will check :
fuel pressure with autozone Guage
vacuum maybe even drop the gas tank to see if there is a bunch of crud clogging up the pump inlet
Old Dec 12, 2012 | 04:31 PM
cadaver666's Avatar
cadaver666 is an unknown quantity at this point
egr valve possibly?
Old Dec 13, 2012 | 12:50 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
Definitely check the EGR for carbon blockage. Clean it out well with carb cleaner and a toothbrush. If a chunk of carbon dislodges it can block the pintle and keep it from closing which causes stalling and dying. I had the same problem with my '93 Sonoma pickup.
Old Dec 14, 2012 | 08:40 AM
OK that sounds like a good candidate since everything else I was checking would probably cause it to not run or run bad all the time, this problem is intermittent and I can see how the egr might just stick open during half a revolution or so.
Thank you for your help!
4.3 vortec
Feb 12, 2015 11:21 AM
bdude273
Nov 22, 2013 08:30 PM
Jimmy76
Feb 22, 2013 05:12 AM
londonmazda
Oct 19, 2010 02:15 AM
AUEngineer
Sep 13, 2010 01:13 AM
