94 jimmy 4.3 hard start or no start and high idle
Old Nov 8, 2013 | 10:29 PM
Kevin Gore's Avatar
Kevin Gore is on a distinguished road
Default 94 jimmy 4.3 hard start or no start and high idle
good evening,
I have a 94 gmc jimmy 4x4 4.3 auto I am have an issue that i thought i had fixed I had it problems with hesitation hard starting then one morning I went out to start it and nothing just cranked had spark and fuel pump worked. So i did some research found out that the cpi had issues with this truck. so i put a new spider and new feed lines in put it all back together started it a presto it was running good still had a high idle issue but it ran so when to school this morning came out to go home and bam it would not start so i towed it home
started checking things out to the ignition module had it tested it was fine checked pickup coil it ohmed OK but the wire's were cracked and had bear spots so i just got a rebuilt distributor put it all back together and no start condition still so i gave it a shot of ether and it started and ran but still have that high idle but it stated to stall and just before it died it caught itself and ran but the idle jumped up high and never came down
things changed
fuel tank (had pin holes in it)
fuel pump(twice)
fuel filter
spider
distributor(cap & rotor as well)
checked fuel pump pressure KOEO 60 Psi when pump turned off pressure drop immediately but my gauge leaks fuel have to fix it and try again
truck running pressure it at 55psi.
im at a loss still having a fuel issue i believe any suggestions or advice and sorry for the long post
Old Nov 9, 2013 | 07:57 AM
chris015's Avatar
sounds fuel pump to me,although its been done twice. Is it a aftermarket $40 pump? these blazers hate em! thing is online you can get a official ac delco pump for the same cost.
Old Dec 13, 2013 | 09:02 PM
warrenandress's Avatar
warrenandress is on a distinguished road
high idle vac leak or isc motor stuck
Old Dec 13, 2013 | 09:35 PM
richphotos's Avatar
Check the codes.
mcdevin1973
Oct 5, 2014 02:52 PM
Zach8846
Mar 11, 2014 10:43 AM
79MKII
Nov 16, 2012 04:14 PM
carpenter625
Apr 22, 2008 09:59 PM
tbrincefield
Apr 15, 2008 09:29 PM
