94' Jimmy idles rough the warmer it gets.
#51
She runs!!!! Like a dream!!
Well i got the jimmy all back together and she runs great now, no more loading up, fuel pressure back to normal, FPR not leaking, fuel line don't leak anymore. No more idling like poo, No more black smoke, heck it doesn't smoke at all now! Wow for a $200.00 truck i guess it will be ok after all. Just needs exhaust now and she'll be ready to drive...... Thanks to everyone for all the help and suggestions!
#52
Congratulations!
#53
#54
Mr Hefner, congrats on your fix!
#55
It sounded like SHHHHHHHHH while the fuel pump was buzzin, no ticking that I could hear. Mine is a 93 vin W 4x4. Yes all the tippets were pissing out fuel, and yes the plenem was full of fuel and my oil was 4L overfull by the time I fixed it and drained the oil (made a great firestarter too). My problem was the tips of the spider not holding pressure, it was like they were on wide open mode. Not just vapor coming out, but LOTS of raw fuel.
#56
hi everyone i have a 94 s-10 4 door blazer 4.6 vortec seems to be doing the same as hubert hefner
i changed all the spark plugs 3 were ok the other 3 were black n caked up it seems to idle a lill rough and on first gear it seems to be missing or something for a sec the she runs fine until i have to stop n start moving again .when it is in drive and i am at a stop it seems to idle really rough like it wants to turn off but it doesn't i usually put it in nuteral . i noticed today the temp gage isn't working i also got black smoke and smells like its running rich i only see the smoke when i get on the gas . i don't smell any gass commming from the engine but i was going to check in the morning i thought it might be a sensor any ideas
#57
#58
yeah they were on the same side passenger side . no i don't have a coder . fuel leak hugh? the day i changed them i rode around the block and the truck felt like it supposed to the next day it went back to acting up i havn't taken the new ones out to clean them if i have a fueal leak on that side how would i go abouts to find it
#59
#60
so far from everything your describing, it sounds like your fuel pressure regulator has gone bad and has started to leak. take out the manifold tuning valve located on the top of the intake and then look in there with a flashlight for small fuel puddles at the bottom of the intake...if you still cant see in there, take off the upper part of the intake so you can look and check for your fuel leak....
