94 s10 Blazer engine sputters and dies
Old Jun 7, 2010 | 08:34 AM
arcwelder's Avatar
arcwelder is on a distinguished road
Originally Posted by swartlkk
Pressure/leak-down test. You need to either verify it as the cause or rule it out.
Yes, I agree.
It's on my to-do list (waiting for the pressure tester to arrive via UPS)
Thanks
Old Jun 13, 2010 | 10:52 AM
arcwelder's Avatar
Finally found the issue...
The Ignition control module (mounted inside the distributor) was apparently bad. When the distributor was replaced, apparently this part was re-used.
With that replaced, car is running fine now.
(ps. passed fuel pressure test and leakdown test with flying colors)
Thanks to all for the assistance!
Old Jun 13, 2010 | 02:22 PM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
LOL as i was reading your thread i was about to post that to check and then the last post you said you found the problem haha glad your running great now
Old Oct 20, 2011 | 07:46 PM
meaty's Avatar
meaty is on a distinguished road
How did you find out that the Ignition Control Module was the cause of the problem? How long did it take to replace? or how much did it cost to replace (if you had it done at a garage)? I am assuming that the truck drove o.k. under higher rpm's, but was idling badly? I have the same 94 s10 blazer and just had the distributor, rotor, and cap replaced because the car would not start. Now the truck starts fine, but I have a very irregular idle and my truck actually stalled today while idling. I didn't have the idling problem before the distributor was replaced.
Old Nov 16, 2011 | 10:03 AM
dan14615's Avatar
dan14615 is on a distinguished road
I read over your thread and problem. I have a 94 chevy s-10 blazer tahoe LT with 147,00 miles and have been through the ringer with recent fuel injection issues. Alot of the issues you stated seemed identical to mine so I figured I'd write what I just went through. My blazer decided not to start intermintantly and I ended up having to buy a new fuel injector regulator at a whopping 400 bucks after ruling out all kinds of other things. It ran like a champ for the next 6 months and now my EGR valve is sticking and the truck is running really rich. I just ordered a new one and got that replaced. I know these S-10's are known for these issues. In your list of things replaced I didn't see a fuel injection regulator so I figured I'd mention it. If it's messing up it could be flooding your engine. Just a thought.
Old Nov 17, 2011 | 01:19 PM
DoubleDouble's Avatar
DoubleDouble is on a distinguished road
I had basically the same problem, turned out to be my MAP sensor. Try replacing it.
A lot of guys on here told me to check fuel pressure etc but that wasn't the problem.
Old Nov 27, 2011 | 04:17 PM
midnightrider's Avatar
midnightrider is on a distinguished road
Have you thought about some sediment stuck on the outside of your fuel pump bag ?? Had the same condition, dropped the tank, cleaned it out, runs perfect....just sayin'....
J
Old Mar 23, 2013 | 11:09 PM
Uncle_boog's Avatar
Uncle_boog is on a distinguished road
Default help
i know this is an old post but i am having the same issue. Fuel pressure tested out and so did the control module. Really not sure whats going on any help would be really really appreciated
Old Mar 24, 2013 | 12:22 AM
clicheche's Avatar
clicheche is on a distinguished road
i replaced my spider injector, and that appears to have done the trick. it would just spew too much gas into the combustion chambers. it flooded out the engine. would crank over and not start... classic sign of flooding.
fairly straight forward replacement.
it would appear that the fuel pressure test is definitely the place to start. ensure you're getting the proper amount of fuel to the engine. from there, you've diagnosed, or at least ruled a few things out.
best of luck!
95blzer95
Jul 9, 2014 05:37 AM
blazinchevy
Jul 31, 2012 09:27 AM
nonfictionsurf
Jun 21, 2011 10:16 PM
kstrange
Jun 6, 2011 06:56 PM
cfrain
Dec 13, 2010 04:02 PM
