94 s10 blazer THE Wall Help Please
Old Apr 13, 2013 | 07:38 PM
94s10blazin's Avatar
94s10blazin is on a distinguished road
Default 94 s10 blazer THE Wall Help Please
I hit the im not going to run right Wall
94 s10 blazer 4dr 4wd w vin . picked up out of jersey drove back down cylinder 3 .
due to spider and fuel kit. replaced both.. added new distributor ,plugs, wires... set timeing , fixed vacuum leaks, cleaned egr , new map sensor . threw my used /new cat in and passed emissions and spection.
now the problem is it still has a miss and rough idle. pop the hood and apply some throttle and hold and she goes to correct rpm then drops slightly and surges .
was also going to put my new o2 sensor on from my retired 94 but it was a 3 wire and this blazer is a 4 wire heated o2 so no go. im used to dealing with these motors . me and my brother/mechanic and me are stumped . also fuel pressure is good .
is there something i missed or does anyone have some helpful input thanks any help much appreciated i'm not wanting to go to STEALERSHIP!
i have access to a shop and some diagnostic tools and two hands Please help
also have a 2-5 sec delayed start witch is odd to me my old one started the instant the starter engaged i would love to fix this tooo
Old Apr 21, 2013 | 08:40 AM
NCSurvival's Avatar
NCSurvival is on a distinguished road
Check to ensure your engine grounds are all proper. Also, when you check timing, does the mark jump around sporadically?
stevo
Oct 19, 2009 05:35 PM
kankoon52
Jul 30, 2007 11:40 AM
Loud_01_Blazer
Jun 5, 2007 12:24 AM
kaps
Tires and Wheels
Jan 4, 2007 10:43 PM
02 Vortech
Jan 15, 2005 06:33 PM
