1987 s10 backfire/pops and cuts out
Old Apr 16, 2013 | 07:55 PM
Surf2live411's Avatar
Surf2live411 is on a distinguished road
Default 1987 s10 backfire/pops and cuts out
Hey guys hoping you can help me here. I have an 87 s10 blazer 2.8 I bought a few months ago. I had the fuel pump and fuel filter replaced initially and was running fine until recently. Its starts right up and idles great while its just sitting, but once it starts to drive, its starts to putt putt and cut out and when I give it gas theres a pop that seems to be coming from under the airfilter/carb area and completely cuts out. I had the distributor, coil, pluggs, wiring all replaced but cant quite figure this out cause it runs so good in neutral. Also checked the gaps in the pluggs and they're at .45 wgphich seems fine to me. Very frustrating, mplease help
Old Apr 18, 2013 | 06:46 PM
bigkhans's Avatar
bigkhans is on a distinguished road
Is there a check engine light on? Also have you verified that there are no vacuum leaks? I'm not all to certain but I would also check the ecm.
Old Apr 18, 2013 | 06:47 PM
chris015's Avatar
depending on what pump they put in,could be the problem. sounds like a fuel issue.
Old Apr 21, 2013 | 08:25 AM
NCSurvival's Avatar
NCSurvival is on a distinguished road
Have you tried checking the EGR valve? It may need cleaning or replacing. Also, make sure your engine grounds are proper as that could cause your issues as well.
Old Apr 21, 2013 | 08:49 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
check ignition timing, fuel pressure and firing order. An injector problem would be apparent at idle, so would a vacuum problem. If ignition timing is too advanced it will idle extreamly smooth but once under load it will throw a fit. Low or high fuel pressure could explain it. If the firing order got messed up it "could" idle fine, then run out bad. Happened to my grandpa's impala, idled great but would breathe fire if you drove it. Lol. Timing should be at 0 degrees
burned
Apr 26, 2013 04:14 AM
daddyrabit
Apr 21, 2013 08:23 AM
hasek1616
Nov 6, 2011 05:21 PM
justinh4578
103
Nov 4, 2011 05:12 AM
ctberry78
Mar 24, 2009 08:33 AM
