ac compressor wont kick on
Old May 28, 2009 | 06:42 PM
daBIGstuff's Avatar
daBIGstuff is on a distinguished road
Question ac compressor wont kick on
I have a 94 s10 blazer 4.3l. The ac needed charged when I got the vehicle. So I disconnected the wire so it would stop kicking on all the time. Well I decided to recharge it and I plunged it back in. But now the compressor won't kick on. I can spin it by hand so its not froze up. I don't understand y it doesn't kick on.
Any help?
Old May 28, 2009 | 08:16 PM
Too low of system pressure will lock out the compressor clutch. You can either jumper the relay for the clutch or put a jumper wire in the low pressure switch that is on the filter/dryer (large silver canister on the passenger side of the motor). This should allow for the operation of the clutch to pull in refrigerant.
Old May 29, 2009 | 02:26 PM
daBIGstuff's Avatar
K. How would I go about jumping the low pressure switch?
*UPDATE*
I figured out how to jump it. New prob! The compressor now kicks on every 5 seconds. For about 2 seconds. But doesn't blow cold air?
Old May 30, 2009 | 02:51 PM
igot10pinitis's Avatar
igot10pinitis is an unknown quantity at this point
not enough freon
Old May 30, 2009 | 04:51 PM
brosko's Avatar
brosko is an unknown quantity at this point
If it didnt have any freon in it when ya first charged it ya should have put a vacume to it if ya didnt any moisture in the lines will freez and fok up compressor .... just my 2 cents
Old Jun 1, 2009 | 07:49 AM
If the system was open to atmosphere and completely depleted of pressure, I would agree. But if a slow leak caused it to bleed down to the point where the low pressure switch was not activating, then a recharge without pump down should work.
Keep on adding refrigerant into the system until it stays on steady and the pressure is in the appropriate zone on the gauge.
skarphace
15
Sep 17, 2012 05:45 PM
insanefirewall
Feb 20, 2011 08:14 AM
gmcjimmy_94
Dec 30, 2010 12:37 AM
gwbufallo
Jun 15, 2010 12:57 PM
jetsmy
Aug 1, 2008 10:10 PM
