After top end rebuild...overheating but not?
Old Oct 26, 2009 | 03:11 PM
Corrupt's Avatar
Corrupt is on a distinguished road
Default After top end rebuild...overheating but not?
OK, got done rebuilding the top end of a 2.8 due to a head gasket problem. Got everything back together and cranked it up. Within the 1st 30 seconds of it being cranked my temp guage shot up into the red. Changed out the temp sending unit and still same thing. Bought a 3rd party temp gauge and changed out the probe to the one that came with the new gauge. Temp goes up to about 240 on it. Is it possible that I could have an air bubble in the system even though I just took the truck on about a 20 mile trip. Got back home and did not hear any signs of an overheating engine. What is the easiest way to "burp" the coolant system.
Old Oct 27, 2009 | 10:47 AM
Corrupt's Avatar
Anybody have any ideas here?
Old Oct 27, 2009 | 11:40 AM
If you suspect entrapped air is the problem, pulling a vacuum on the cooling system is a tried and true way to get the air out. If that is not a possibility, then you need to elevate the front end of the truck as high as you reasonably can with cap side of the radiator slightly higher so that it is the highest point in the system. Run the engine with the cap off until it reaches operating temperature. Let it cool. Add coolant as necessary, repeat. You are likely to spill some coolant out of the radiator as the engine warms up in subsequent heat cycles, but it will burp the air out.
Applying a vacuum to the system really helps to get the air out though.
Old Oct 27, 2009 | 01:06 PM
92s10Blzr's Avatar
92s10Blzr is on a distinguished road
i've never heard of a vacuum on the cooling system, can you explain how to go about this?
Old Oct 27, 2009 | 02:30 PM
You can either do it with a purpose built cooling system vacuum filler or make your own with a hand vacuum pump. Making your own isn't all that difficult, but you do have to make up a filler cap that seals to the lower portion of the radiator fill neck.
When the system is under a vacuum, the air will be a lot easier to remove.
Attached is a picture of the purpose built cooling system vacuum filler I mentioned. It uses shop air to pull the vacuum and has the capability of pulling coolant in as well. Snap-On as well as quite a few other major tool manufacturers sell this type of tool.
Attached Thumbnails After top end rebuild...overheating but not?-vacuum_filler_example.jpg
Gambit66
Jan 3, 2016 04:04 PM
Wolvezbane
Dec 13, 2013 08:21 PM
Rumblur
Jan 9, 2013 02:24 PM
88s10Blazer
Dec 25, 2007 09:29 PM
90blazinchevy
Oct 5, 2007 01:52 PM
