Alarm system
Old Sep 6, 2007 | 08:53 AM
_Sweet_S10's Avatar
_Sweet_S10 is an unknown quantity at this point
Default Alarm system
hi i a m trying to install a clifford concept 100 and i am just wondering ,when trying to run the wire from the clifford unit to the factory door trigger wire do i use a butt connector and connect all three wires??
Old Sep 25, 2007 | 07:42 PM
neeper74's Avatar
neeper74 is an unknown quantity at this point
Default RE: Alarm system
first of all, what year is your truck? if it is a first gen, then you should use the neg alarm trigger (usually green) and connect via t tap, splice with tape or solder to the orange lead on the under dash light. if it is a second gen with the dome override you need to use the green trigger (negative) and connect to the purple lead behind the headlight switch. hope this helps. any other questions please feel free to ask.
Old Sep 25, 2007 | 08:21 PM
hillbillyinOhio's Avatar
ORIGINAL: neeper74
This information is wrong on every year of our trucks. Please do not give out false information. Giving out incorrect wiring information can cause lots of problems and blazerforum will not be held liable for mis-information
What year and kind of truck are we working with???
Old Oct 3, 2007 | 08:53 PM
FRICKINNUTS's Avatar
FRICKINNUTS is an unknown quantity at this point
Dang! Sure could have burned up something!!
Just use the wire coming of the pin switch in either kick panel. I don't remember the color code of the clifford but the wiring instruction should have which 1 ONE wire goes to neg. trigger. Opening any door throws a ground at all switches.
megaroos_00
Jul 1, 2008 10:59 PM
jukdd
Jun 21, 2008 03:34 PM
gocartone
Oct 19, 2007 06:20 PM
03blazer
Apr 12, 2007 11:34 AM
wexfordmike
Mar 18, 2007 08:51 AM
