Anti-Lock light on?
Old May 7, 2009 | 03:15 PM
classklown90's Avatar
classklown90 is on a distinguished road
Default Anti-Lock light on?
My anti-lock light is on in my 94 blazer, does this mean i should get the brakes checked? they seem fine but idk what else itd be. Also does this year blazer have a low gas light? I didnt see one turn on when my car ran out of gas.
Old May 7, 2009 | 03:39 PM
I do not believe that your truck has a low fuel light.
About the ABS light, it could either be a simple problem or a complex problem. A simple problem would be a cut front wheel speed sensor wire or a dirty WSS sensor. A complex problem would be an issue with the ABS control module itself. Without getting the ABS system scanned, you really will not know. You could do a visual inspection of the front suspension to see if the wiring is intact.
Old May 7, 2009 | 04:41 PM
ok thanks ill check that
mustardrocket
Jan 4, 2015 06:15 PM
olympia1979
Sep 6, 2010 01:01 PM
salvy
Nov 5, 2008 10:17 AM
oldspwr
Jul 26, 2006 10:13 AM
djestes
Dec 29, 2005 08:02 PM
