bad idle when stopped
Old Aug 29, 2010 | 03:29 PM
olympia1979's Avatar
olympia1979 is on a distinguished road
Default bad idle when stopped
hey everyone. i have a 91 s10 4.3l and ive been having some minor issues with it. whenever im driving its running fine. but when i come to a stop, it starts to shake a bit. i start to go and its fine. also when i give it more has my "service engine light" turns on. i replaced the egr and nothing happened. same issues. does anyone have an answer for this? i was told that it could be the iac valve. where is it located? thanks
Old Aug 29, 2010 | 04:20 PM
The iac valve is in the throttle body.
What is the code that is being reported?
Old Aug 29, 2010 | 06:42 PM
Sleazy_E's Avatar
Sleazy_E is on a distinguished road
I have this same problem in my 91 Blazer. Another sign I've noticed is an extreme drop in oil pressure.
What I've been told is that there's a vacuum leak somewhere. Any ideas?
Old Aug 30, 2010 | 05:57 PM
i have not hooked it up to a scanner. im going off info on the internet and what people have been telling me.
Old Aug 30, 2010 | 06:06 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
yea, sounds like a vacuum leak or a intake gasket leak. you can spray carb cleaner around your intake gaskets, and if the engine smooths out or revs up then you have a leak. also check your vacuum lines for dry rotting
Old Aug 30, 2010 | 08:30 PM
You don't need to hook up a scan tool to read the codes. A paper clip is all that is required. Check out TroubleCodes.net for how to check codes on an OBD1 vehicle.
Old Aug 31, 2010 | 09:58 AM
thanks for the tips. ill be doing both of them. is it safe to read the codes with a paper clip? ive never done that before.
Old Aug 31, 2010 | 07:14 PM
just did a code check with your tip swartlkk. thanks for the tips everyone. it looks like its my oxygen sensor thats faulty.
LannyL81
46
Dec 25, 2019 09:54 AM
tim68
Jan 11, 2011 10:30 PM
1996blazer1
Jan 24, 2010 03:36 PM
nathansr06
Nov 30, 2008 04:43 PM
mac6135
Dec 8, 2007 09:18 AM
