rough idle when stopped or parked
Old Jan 20, 2010 | 04:57 PM
1996blazer1's Avatar
1996blazer1 is on a distinguished road
Default rough idle when stopped or parked
Hey, my trucks been having this problem for a few months now. when i start it up it idles high until up to temp and the it gets rough. also whenever i come to a stop or park it comes back. its not having a impact on how the truck drives its just annoying to have my whole truck vibrate at the stop light even my antenna shakes a little bit. if you have any suggestions just let me know thanks.
Old Jan 20, 2010 | 09:44 PM
terry s's Avatar
terry s is on a distinguished road
Check for a possible vacuum leak.
Old Jan 21, 2010 | 11:38 PM
I checked for vac leaks and couldnt find any. plus my vents and 4x4 are working fine. any other ideas?
Old Jan 22, 2010 | 01:18 PM
awe341's Avatar
awe341 is on a distinguished road
If you can't find any vac leaks then I would start checking for carbon buildup on both the IAC valve (idle air control) and the EGR valve. It could be causing them to stick badly enough to effect performance but not quite enough yet to throw a code.
Old Jan 22, 2010 | 03:22 PM
ok I will try to look at them later tonight. thanks for the advice. Also I might try some seafoam because im going to need an oil change in 400 miles anyways.
Old Jan 24, 2010 | 12:14 PM
im working on cleaning the tb and iac right now il try to snap some pics
Old Jan 24, 2010 | 12:19 PM
speterson1011's Avatar
speterson1011 is an unknown quantity at this point
Default idle
I would check for vacuum leaks, clean your MAF, air filter, clean your throttle body as well. Most likely it will be a vacuum leak. Check your spark plugs to they could be misfiring.
Old Jan 24, 2010 | 03:36 PM
ok here it is i just got back to my gf's and now can post the pics I took. I cleaned the IAC,TB,air filter, MAF. The truck seemes to idle better now and I got allot of carbon crap ut of there. hers are the pics. There was actually a build up of crap in the IAC that came to a point and was just nasty. The TB was pretty nasty too. and I think the last pics is of my truck almost back together. I would suggest that if you havent cleaned your IAC by 158k like me to do it. I could notice allot beter throttle response right when I started it up. I hope my problem dosent come back now. o well im hittin the road. thatnks for you comments and help.
o ya I still need to change my plug wires but thats for another day.
Attached Thumbnails rough idle when stopped or parked-pict0101.jpg   rough idle when stopped or parked-pict0103.jpg   rough idle when stopped or parked-pict0108.jpg   rough idle when stopped or parked-pict0110.jpg   rough idle when stopped or parked-pict0115.jpg
LannyL81
46
Dec 25, 2019 09:54 AM
abig84
Jun 20, 2011 08:41 PM
drew_fur
Jun 9, 2011 11:46 AM
nathansr06
Nov 30, 2008 04:43 PM
mdkuni
Oct 3, 2008 01:04 PM
