battery ground
Old Oct 14, 2008 | 06:42 PM
frongc's Avatar
frongc is an unknown quantity at this point
Default battery ground
i need to know where the battery negative ground wire connects to the engine block... a pic would be great but any advice would be accepted.
Old Oct 14, 2008 | 08:08 PM
Default RE: battery ground
What are you working on here? Engine?
The typical location is on the back of the passenger side head.
Old Oct 14, 2008 | 09:29 PM
rogggg1020's Avatar
rogggg1020 is an unknown quantity at this point
on my 2.8 carbed its mounted on the alternator mounting bracket but im not sure if thats right anymore
Old Oct 15, 2008 | 05:53 AM
frongc's Avatar
sorry i should have posted it already.. its a 87 s10 blazer with a 2.8 v6.. i know it mounts somewhere in the front of the motor but im not sure exactly where
Old Oct 15, 2008 | 06:37 AM
Yeah, I did not know how far back to go. With the newer 4.3L, the ground is at the back of the passenger cylinder head. On the 2.8L, it could either go to the alternator bracket as stated, or to a accessory mounting bolt on the front of the cylinder head.
Old Oct 15, 2008 | 03:42 PM
frongc's Avatar
thanks
Old Oct 15, 2008 | 06:52 PM
neo71665's Avatar
It uses the bolt on the small steel bracket on the inside of the head holding the alt. The cable runs under the alt to the battery.
eljorgin
May 21, 2019 10:04 PM
TigaHotty85
Jun 17, 2013 03:10 PM
chevyman93
Dec 17, 2012 05:59 PM
tnw912
Jan 5, 2010 05:27 PM
cide
May 1, 2009 01:07 PM
