Blazer experts I need your help again
Old May 11, 2006 | 03:59 PM
2kSnakeEater's Avatar
2kSnakeEater is an unknown quantity at this point
Default Blazer experts I need your help again
I have an 87 2.8L 4x4, I am going to have convert it into a 5.7L 4x4 to tow what I want with it. I cannot use the 2.8L auto tranny on a 350, I do have the chance to pick up a 93 2wd 4.3 s10 for cheap, my question is:
Can I use my 4x4 trans axle and bolt it up to this trucks 4.3L tranny? I have heard that the 4.3L tranny will bolt up to a 350 is that also correct?
Old May 11, 2006 | 08:43 PM
Default RE: Blazer experts I need your help again
I believe that the '87 trans is a 700r4 and the '93 is a 4L60... Although they are conceptually the same, I am fairly sure that there are small differences that would prohibit you from putting your transfer case on to the 4L60 transmission. Besides, to go from a 2wd trans to a 4wd trans, you have to change out the tail housing and the output shaft to ones that are made to bolt up to the transfer case. It is these parts which are most likely of different designs between the two years you are working with...
Old May 11, 2006 | 11:17 PM
Yep, too much work. so what year trannys can I use on my 87 Blazer? I know I need the 4.3 4wd 700r4
CanadianaBlazer
Apr 3, 2014 10:33 AM
Chic_Bowdrie
Jul 3, 2012 05:50 AM
El Diablo793
Lifting Tech
Sep 10, 2011 01:21 AM
amnotblonde
Jun 10, 2011 11:15 AM
kiwiblazer
Feb 4, 2011 11:59 PM
