Blazer-no idle, dies, then starts up
Old Aug 29, 2009 | 06:40 PM
redneckwoman's Avatar
redneckwoman is on a distinguished road
Default Blazer-no idle, dies, then starts up
91 chevy Blazer would rire up drive about 1/2 mile then die, so I added a cleaner this got us home. Then replaced the inline fuel filter it got worse. It would fire up run then die then refuse to start, after a while it would start run then die again. I relaced the cap and roter but nothing I then replaced the fuel pump, filter cleaned the lines, cleaned the tank, replaced all the o-rings and gaskets and rebuilt the injectors, nothing. checked the injectors then replaced them, nothing, then I ran the codes and it gave me a 12 that says it the control module that needs to be replaced. The only problem is that ther are 4 typed of control modules on a vehicle, so the internet states. so would it be the electronic spark control module? If not than which one?
Old Sep 3, 2009 | 12:04 PM
tronsch's Avatar
tronsch is on a distinguished road
you should change the ignition module and the wires.had the same problem on my car
rustyiron
Apr 21, 2012 11:28 AM
reddheadnla
Apr 23, 2011 11:08 AM
sk8_dude90
Nov 30, 2010 02:25 AM
Blazer Will
Dec 13, 2009 06:22 PM
TTATE
Aug 11, 2009 07:43 PM
