Bought a old 89 blazer idles then dies....HELP
1989 4.3l 135,000 miles...
replaced dist.cap, rotor button, plugs, plug lines, coil, fuel filter
truck starts up idles real good for about a 3min then kills it self out.. i thought the CAT was plugged so chopped exhaust it was shot anyhow.. new exhaust to come.. still didnt fix..
any suggestions???
also when you drive down the road it runs bad at low rpms if you run it hard in 1st or 2nd gear with the rpms up runs alot better..... help me out
any suggestions???
checked for leak under the TB none found... took off EGR and cleaned still running like crap... what would a bad ICM module do would it do something like this... its not showing any codes and check engine light not on but everytime i mess with it i unplug the battery so it wont go dead............. any help.............. kind of smells like it is running rich.....
tagodwin23
Feb 3, 2013 12:39 PM
smitchelle
Jan 5, 2012 11:24 PM
cfrain
Dec 9, 2010 07:05 AM
blbikerood
Jan 19, 2010 06:09 PM
