brake problem??
brake problem??
the last couple of days its been snowy out and i noticed whenever i press really hard on the brakes and start to slide in the snow my brake peddle kicks back at me and it sounds like sumones banging on the floor underneath the drivers seat...that cant be normal any ideas? i had an ABS light on for a while but i took it to the local mechanic and he erased the code it hasnt come on since
RE: brake problem??
That sounds like the normal function of the ABS. It's the valves constantly modulating the brake pressure trying to keep your brakes from locking up.
RE: brake problem??
Yup, normal operation of the ABS.
RE: brake problem??
LOl, I'm not the only one..
I think this truck has the WORST brakes on any vehicle I have ever owned...The Yellow lights up here are quick and you really have to anticipate the light or you will end up in the middle of the intersection sliding or notacross the painted lines......I went as far to pull the wheels and check the pads etc to make sure they where not cracked,glazed over etc...Nope, nothing wrong mechanicly...
RE: brake problem??
That's old school ABS for ya! lol
It makes especially loud noises if it's on just the rear wheels.
RE: brake problem??
My truck has no trouble braking even loaded down quite heavily... The type of pad installed has A LOT to do with how good the vehicle slows down.
RE: brake problem??
o arite does ur guys bang alot,and make a lot of noise when u slide in snow?
RE: brake problem??
Mine doesn't...
RE: brake problem??
It depends on your definition of a bang?... Mine sounds like a spring being hit very rapidly when it happens.
RE: brake problem??
mine sunds like a hammer bangin on my floorboards
