Brake problems/1994 Chevy Blazer
Old Dec 21, 2009 | 04:59 PM
ChevyLover's Avatar
ChevyLover is on a distinguished road
Red face Brake problems/1994 Chevy Blazer
Hello, I own a 1994 Chevy Blazer that had not been driven for over a year until recently ( 2 month ago) when I had it fixed. I needed new Distributor, new Radiator, new Fuel Injector and a engine rebuilt. The car was driving fine and I have no engine problems, but now something is wrong with my brakes. I drove it the other day and while pushing the pedal to come to a stop the resistance from the pedal was gone all of a sudden and the pedal went all the way down. I had to pump the pedal a few times to get it to stop again. Yesterday the same thing happened but now pumping the pedal das not work anymore . it just goes straight down to the floor. I know my pads are fine since they got replaced right before the car broke down originally. If anyone can help me figure this out I would greatly apreciate it.
Old Dec 21, 2009 | 08:58 PM
Is your master cylinder full? Did you inspect the brake lines for leaks?
Old Dec 21, 2009 | 09:04 PM
oisinirish's Avatar
X2.
Be sure to check around the calipers and drums as well for signs of fluid.
Old Dec 21, 2009 | 09:46 PM
mr.vls's Avatar
Master Cylinder failing, Leaks, broke brake line. You might want to pull the rear brake drums to check the wheel cylinders. Could be leaking inside of the brake drum.
Old Dec 22, 2009 | 11:57 PM
ChevyLover's Avatar
Thank you for all the suggestions. I will definetly check all that out.
Alexandra
ThaDopeShow
Aug 18, 2015 07:30 AM
bertrenolds
Feb 17, 2011 04:05 PM
steve25537
Feb 15, 2011 10:56 PM
94BlazerKid
Nitrous, Super Chargers, & Turbos
Apr 28, 2009 03:38 PM
mbmiller
Sep 2, 2008 09:51 PM
