1994 chevy S-10 blazer 4x4 transmission fluid capacity
Old Oct 15, 2010 | 08:05 PM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
Default 1994 chevy S-10 blazer 4x4 transmission fluid capacity
I just changed my transmission filter and only have a chiltons for 83-93 and it says 4.4 pts, is that right for the 94 and how many quarts is that? Or just tell me how many quarts is recomended for a 94 4.3 vortec engine w. Thanks
Old Oct 15, 2010 | 08:40 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
I'm pretty sure you need 4 qts, not 4 pints. And I'd have 5 qts on hand, just in case.
Old Oct 16, 2010 | 08:55 AM
Thanks, I will put the rest of the gallon of fluid in there. I was getting a reading or what looked like a cold reading but it's just easier to know about how much it needs.
Old Oct 16, 2010 | 09:01 AM
You need to check the level on the dipstick first. Then warm it up to operating temperature, running it through all the gears. Then check the dipstick again. Be careful to get the level right - overfilling is as bad as underfilling.
Old Oct 16, 2010 | 09:03 AM
I did a cold check and I went through all the gears and then let it idle for 3 min then checked it. Do you have a chiltons you could check real quick to comfirm the fluid capacity?
Old Oct 16, 2010 | 09:12 AM
According to the factory service manual, drain and refill (filter change) is 5 qts.
Old Feb 17, 2011 | 11:47 AM
rastoma's Avatar
rastoma is on a distinguished road
Did you have to remove the cross member near the end of the transmission to get the pan off?
Old Feb 17, 2011 | 04:05 PM
ffox's Avatar
ffox is on a distinguished road
The 4.4 pts. is for a 5 speed transmission....
irondooks88
Jun 21, 2010 03:58 AM
republic
Oct 12, 2009 04:58 PM
TAZ454
Feb 1, 2008 02:57 AM
corr33
Oct 31, 2007 06:59 PM
KennyJonson
Dec 26, 2006 06:09 AM
