Break peddle goes to the floor
Thanks again to all, I'll be looking in to all this shorty and let you know. and no the light is not coming on. in the back of my mind i keep hearing vacuum leak. What do you think about that > Kim- Show quoted text -
My brakes are spongy as well, but I am not getting an ABS light. Will try bleeding the brakes this weekend to see if it helps.
Thank you, but I already know what's wrong. My EHCU modulation valve is bad. When the trouble came my way I figured that was the problem. I took it to the Chevy house and let them check it out. At 1st they said its the master cylinder, and I let them put a new one on. Just as I thought, that was not the problem. After further testing they said its the EHCU modulation valve, cost for the valve is a bit over $1000,00. I declined, they did not charge me for the new master cylinder nor the labor.
As I said earlier I bought a EHCU modulation valve off of a wrecked Blazer S10, it worked quite well for about 1 year, them it went down.
I did not have no trouble bleeding the air out when I put the used EHCU modulation valve on, of course it took me nearly half a day to accomplish the task of just bleeding my brakes. It just take patients.
I might add, my fix cost me nothing, and my brakes works great. The only reason I posted about is that it might just help to someone else while saving them lots of trouble, and money.
Edited to add, I never did have a dash light come on letting me know something was wrong with my brakes.
SOTO
12-02-2011 12:35 PM
hotrodsbyg
07-03-2010 02:37 PM
kodie
08-13-2009 02:36 PM
naf821
08-08-2007 07:19 AM
