Cable and vacuum actuator questions
Old Mar 24, 2020 | 08:47 PM
cavecookie's Avatar
cavecookie is on a distinguished road
Default Cable and vacuum actuator questions
Hey all! I have a few simple questions I hope you folks can help me with. I have a 94 4.3 CPI S-10. I have a vacuum issue and discovered the culprit is a vacuum actuator that sits in the engine compartment, just in front of the brake booster, and under the brake fluid resevoir, and is part of the cruise control. Easy to get to, but what is that bad boy called? I can't replace a part I can't even name. Next, while looking at the cruise control system, and my Haines Manual, I discovered a missing cable that belongs on the throttle valve linkage, something they call a "TV" cable. What the heck is it, and where does the other end belong?
Old Mar 25, 2020 | 11:32 AM
Wow, (as a mod) I really screwed up Christine's message trying to simply post in this thread. Sorry! Les Myer
Old Mar 26, 2020 | 04:00 AM
servo, cruise control, sorry I do not own a parts catalog.
I use the www.gmpartscenter.net for the drawings.
Old Mar 26, 2020 | 12:46 PM
What transmission do you have? If it's a 4L60E, you don't need a TV cable. That's only for a 700R4.
Old Mar 26, 2020 | 02:14 PM
LesMyer's Avatar
Cruise Control Servo like Error 401 said. Cruise control cable hooks up to the throttle body. No TV cable.
Old Mar 26, 2020 | 04:27 PM
cavecookie's Avatar
Well, that explains why the TV cable isn't there! And, I finally figured out that that vacuum actuator for the cruise control is the "cruise control servo". Dang, it seems half the battle with these vehicles is just trying to find out what the freakin' part is called! I would never have guessed it's called a servo...my experience with servos is that they are electrically operated components! Anyway, thank you all for your help with my silly, trivial problems!
Old Mar 26, 2020 | 05:29 PM
cavecookie's Avatar
And, after removing that servo, I find that it IS an electrical component! I guess I can say I learned something today.
Old Mar 26, 2020 | 05:31 PM
cavecookie's Avatar
Well, without looking up that info, I would guess that I have the 4L60E, since my rig doesn't seem to have ever even had that cable.
Old Mar 27, 2020 | 08:07 AM
I don't think that from 92 onwards they fitted the 700R4. AFAIK from latest 92 it's all 4L60 and from 94 4L60E. (At least that was OEM)
blaze77
Nov 29, 2011 03:05 PM
pmezo
Feb 3, 2009 06:00 PM
bman192000
28
Nov 12, 2008 04:50 AM
bigjohn1139
Jan 17, 2008 12:27 PM
badfxr
Dec 23, 2005 07:45 PM
