caliper brake hardware kit?
Old Dec 26, 2008 | 04:25 PM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
Default caliper brake hardware kit?
Just got new caliper bolts/pins and also got a hardware kit to replace the sleeves. I know what most of the parts are for but their are 3 little o-rings, maybe should have been 4, but anyways I have no idea what they are for. I took a picture so if anyone has used a hardware kit before please let me know what the smaller o-rings are for.
[IMG]local://upfiles/10328/B19FEBD29B894A28B23B9E8B03CC041A.jpg[/IMG]
Old Dec 26, 2008 | 07:53 PM
Default RE: caliper brake hardware kit?
What is this for??
Old Jan 1, 2009 | 03:58 PM
daroach1's Avatar
daroach1 is an unknown quantity at this point
They go on the unthreaded end of caliper bracket. Your pin is threadead near the head and the bottom of the shaft is not threaded. This smaller o ring is used for keeping that loose end in place and prevent it from rocking when torsion is aplied to the caliper.
I believe an exploded view of the caliper bracket in any service manual will show this.
Old Jan 1, 2009 | 04:31 PM
My question was not directed at the items in the photo, but the vehicle being discussed. Basic information that is required to make sure that all information given is accurate.
Old Jan 3, 2009 | 12:20 AM
quik1964's Avatar
quik1964 is an unknown quantity at this point
the last caliper and pins i replaced did NOT have any o-rings
91 4wd
Old Jan 6, 2009 | 01:15 PM
daroach1's Avatar
Point taken.
Old Jan 6, 2009 | 04:55 PM
it is a 94 s10 4.3 4x4 engine w. I ended up using the existing big orings for the pins because I couldn't get the new rings in and be able to push the pins through. drove to colorado from mn and had no problems with my brakes so i'm guessing you only need the big oring if you can get the pins through them and the new sleves and lots of brake grease. I couldn't find any use for the smaller orings so hopefully they are not needed on my truck.
glow
May 9, 2012 09:47 PM
coolen
Mar 26, 2012 08:22 AM
97winterblazer
Sep 29, 2010 05:08 PM
tamikarivers
Tires and Wheels
Feb 19, 2010 01:07 PM
