check engien light
Old 11-23-2012 | 12:57 AM
big_charms@hotmail.com's Avatar
big_charms@hotmail.com is an unknown quantity at this point
Angry check engien light
hello on my way home from work tonight my
check engien light started to flicker, mainly
when i acellareted harder. and when the light
flashed the thermosat jumped up then back
to reg temp, any ideas
my truck is a 1991 jimmy s15
4.3 2 wheel drive with 237000km
Old 11-23-2012 | 05:51 AM
neo71665's Avatar
So what code(s) did it throw?
pulling your own codes.
Old 11-23-2012 | 07:42 AM
havent had a chance to check codes yet but im gonna try for it today
Old 11-23-2012 | 01:53 PM
neo71665's Avatar
Well honestly ya can guess at parts and solutions all day long. Ya can replace every part on the truck but one and that be it. Pull the codes and we can go from there using our heads instead of luck.
Old 11-23-2012 | 10:51 PM
sorry i didnt have time lastnight due too getting home from work at 11.30pm and i didnt have time today cause it took longer to take the trailer hitch ball off so i can tow a trailer once, ill try tomarrow. i was told buy a buddy that it could be the temp senser that goes in the block?
Old 11-24-2012 | 07:46 AM
neo71665's Avatar
You have 2 temp sensors. One for the gauge and one for the ecm. The one for the gauge goes bad the gauge will act up but won't throw a SES light. The one for the ecm goes bad it will run like crap and throw a SES. Stuff like that is why I'm not gonna guess.
Old 11-26-2012 | 11:58 AM
ohsofly's Avatar
Cant help ya till you grab a paperclip and spend 2 mins getting the codes. Dont be lazy.
Old 12-04-2012 | 08:51 PM
hey i checked the codes and realized that its not the check engien light its a check gauges light? any ideas??
Old 12-04-2012 | 08:52 PM
sorry for the delay i havent been able to poast anything on hear
Old 12-05-2012 | 12:34 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
If it's the "Check Gages" light then it makes sense. Whenever the gauges show something out-of-range that light will come on to alert you. Here's what you should do: check the sensor in the passenger side cylinder head. It's the one that gives the temp reading for the gauge. You should be able to find a reference table either in a manual or somewhere on the Internet that should tell you the resistance of the sensor at particular temperatures. Check the sensor with an ohm meter and see if the sensor reads within spec. Also check the wire going to the sensor by grounding it to the battery with the key on, engine off. The gauge should go all the way to the top with no resistance in the circuit. If the gauge pegs on that test then the gauge and the wiring are both good.
After those tests post back with the results.
Quick Reply: check engien light
