Check engine light
Old Mar 5, 2008 | 06:37 PM
countryguy1713's Avatar
countryguy1713 is an unknown quantity at this point
Default Check engine light
My check engine light came on today and someone told me to plug 2 paperclips in the to computer plug in and turn the key on...when i did this the check engine light flashed once paused then flased twice so im guessin that means the code is 12...does anyone know what that means or how i can find out what it means
Old Mar 5, 2008 | 06:52 PM
Default RE: Check engine light
In looking back through all of your threads, I see that you have a '93 4x4. Please include this information in your posts if you are seeking help with a problem so those of us wishing to help do not have to dig for that information.
*Moving to 1st Gen Tech*
Does this pertain to the two other threads you have open on the subject of rough idle? If so, please try to keep everything together. I will be closing your other threads in an effort to consolidate things down to a single problem thread. This will reduce overlap in suggestions and avoid confusion.
Old Mar 5, 2008 | 06:57 PM
Oh yeah that probably would be a little helpful
its a 93 s10 blazer with a 4.3 LVin W
Old Mar 5, 2008 | 07:16 PM
Does the CEL only blink the 12 and then nothing else? If there are more codes pending, it should blink 1, then 2, longer pause, then the next two digit code. If I remember right, it should flash 12 again when all of the codes have been displayed...
Old Mar 6, 2008 | 02:19 PM
86S10's Avatar
86S10 is an unknown quantity at this point
wait, do all 1st gens have this paperclip trick?
Old Mar 6, 2008 | 02:53 PM
Yes, all 1st gens with OBD1 should be able to be diagnosed with the paper clip trick. If you have a plug under the dash, you should be able to do this. Trucks with a carb, well... You don't have OBD..
Old Mar 7, 2008 | 06:28 PM
Hanr3's Avatar
It should repeat the codes three times.
zombiewoof
Feb 1, 2009 12:06 PM
zoniah
Jun 2, 2008 08:45 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
