Check Engine Light /93 S10 Blazer
Old Mar 1, 2008 | 12:17 PM
deadeyeden's Avatar
deadeyeden is an unknown quantity at this point
Default Check Engine Light /93 S10 Blazer
Would anyone know what would cause the check engine light to come on only when it is idling.If you push the gas pedal a little 1 or 2 times while idling ,it will go out between 10 & 15 seconds then come back on.While you are driving it does not so much as flicker on. Would really appreciate the help.
*Moved to 1st Gen Tech*
Old Mar 1, 2008 | 03:06 PM
Hanr3's Avatar
Default RE: Check Engine Light /93 S10 Blazer
Welcome to teh site.
Get the codes read. Even if the light goes off it will store the codes for a while.
Check with your favorite autoparts store, most read codes for free.
Post up what they tell you and we cna point you in the right direction.
Old Mar 1, 2008 | 07:28 PM
94blueknight's Avatar
94blueknight is on a distinguished road
there was a recent thread on how to read the check engine light codes by how many times it flashed. u can search i wasnt able to find it i think hanr3 posted it im not sure tho i'll keep lookin tho
Old Mar 3, 2008 | 10:47 PM
deadeyeden's Avatar
I purchased a G.M Computer Code Reader and it put out code#12(diagnostic mode;no distributor signal to electronic control module;system pass) and code #35(Idle speed control or circuit failure or idle air control valve or circuit failure).Would these be difficult to locate and change.
Old Mar 3, 2008 | 11:02 PM
94blazer4.3ho's Avatar
94blazer4.3ho is an unknown quantity at this point
code number 12 is not a part that needs to be replaced its more like a "system check" as i under stand. code 35 idle air control valve is a part under the plastic decal VORTEC. All you should need is a torque set to replace.I am not sure if it is something that can be cleaned, and reused.
Old Mar 4, 2008 | 09:30 AM
deadeyeden's Avatar
thank you for the info greatly appreciated
Old Mar 4, 2008 | 09:37 AM
deadeyeden's Avatar
I greatly appreciatly the help.I am going to change the idle air control valve and see if that fixes my problem.I will let you know & thanks once again.
Old Jun 2, 2008 | 10:14 PM
JoPre's Avatar
JoPre is an unknown quantity at this point
what ever happend here??
Moridin
Mar 25, 2010 01:55 PM
zoniah
Jun 2, 2008 08:45 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
45auto
Feb 24, 2005 09:30 PM
