'94 S10 Blazer Check-Engine Light
Old Mar 24, 2010 | 02:49 PM
Moridin's Avatar
Moridin is on a distinguished road
Default '94 S10 Blazer Check-Engine Light
Trying to get my '94 blazer back into working condition.. so far so good. It starts up just fine, but after driving it on the interstate at ~70mph for around 20-30 minutes and then exiting it starts to lurch/shudder and the engine sounds like someone is pressing the gas and then releasing, and the wonderful yellow CE light comes on...
There is also a noticeable gas smell around the car while it's running.. but nothing is leaking under the car. Could it be something in the fuel lines? Too much air? I'm not much of a mechanic, so any tips are very much appreciated
Old Mar 25, 2010 | 01:51 PM
juddkennedy's Avatar
juddkennedy is on a distinguished road
I am not sure what city you are in but most autp shops will run the engine light test for free. The codes will tell you what is failing. With the smell of gas, sounds like you may need a dist and coil replacement. Does it hesitate? May just want to get a tune up. Plugs, wire, dist cap and coil, air filter and check the O2 sensors. Good luck, post follows up on the tests.
Old Mar 25, 2010 | 01:55 PM
You can run the codes yourself for the cost of a paperclip. Check TroubleCodes.net for the procedure.
The CPI motor that your truck is equiped with has a problematic fuel system. It is possible that you have a leak internal to the engine which is causing it to run very rich.
deadeyeden
Jun 2, 2008 10:14 PM
zoniah
Jun 2, 2008 08:45 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
45auto
Feb 24, 2005 09:30 PM
