clutch fluid
Old Jan 24, 2007 | 04:31 PM
iceman1987's Avatar
iceman1987 is an unknown quantity at this point
Default clutch fluid
to me it seems every time i look at my clutch fluid resevour it looks like i am lossing clutch fluid. but i am not leaking it. the only thing i am leaking is oil. so where could the fluid be goin or is there something i can do from lossing all of that fluid?
Old Jan 24, 2007 | 11:53 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: clutch fluid
Check under the dash where the master cylinder comes through the firewall. Most of the time the master will leak where the rod goes into the master. Also check the slave cylinder. Korey
Old Jan 25, 2007 | 11:15 AM
rooster's Avatar
rooster is an unknown quantity at this point
what year blazer is it. my 99 has an internal concentric slave cylinder. i let it sit for a few months thru a winter (2wd). came back in the spring and found out that the seals on the slave cylinder had worn out and all the fluid was draining into the bell housing. its not hard to change but not fun either. get a haynes or chilton and follow the steps for backing out the tranny. and get alot of rags!!!!!
Old Jan 25, 2007 | 04:00 PM
iceman1987's Avatar
its a 1989 s-10 blazer and for what its worth i have had no problems with my truck(knockon wood) you know except for the minor replacement parts.
Old Jan 25, 2007 | 08:47 PM
rooster's Avatar
ok then ur slave cylinder is on the outside of the tranny in pretty plain site, i believe on the drivers side. but if u dont see any leaks then i would rule that out.
my suggestion would be to add fluid into the resevior and have someone press on the clutch pedal while u try and trace where the fluid is headed. listen for any drips inside the bell housing.
MintyMadness
Jul 13, 2011 12:37 AM
Red03
Sep 25, 2008 08:37 PM
bootNreboot
Sep 20, 2008 08:32 PM
reayb
Feb 16, 2008 12:41 PM
blownslt
Apr 18, 2007 11:39 PM
