code 22,23,33
code 22,23,33
the check engine light came on so i bought the obd1 or whatever its called. and it gave the code 12,22,23,33 i replaced the MAF sensor but it is still giving me the same codes...........why?
RE: code 22,23,33
Would be more helpful if you put your truck information in a signature and turned on signatures with posting...
RE: code 22,23,33
ok, sorry bout that. 1989 s-10 blazer 2.8 v6 4x4.
RE: code 22,23,33
did you clear the codes after you replaced the MAF?
DTC - 12 No distributor reference pulse (diagnostic test active)
DTC - 22 Throttle position sensor error (signal low)
DTC - 23 Intake air temp sensor error (low temp indicated)
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
Looks like replacing the MAF was not the issue. Looks like you have vacuum leak for one. And possibly a bad TPS sensor.
RE: code 22,23,33
how do you clear the codes? unplug the neg?
RE: code 22,23,33
ORIGINAL: iceman1987
RE: code 22,23,33
thanks, i will try that
RE: code 22,23,33
If the codes return ref. back to my first post. It has the list of each code you posted.
Good luck
Good luck
RE: code 22,23,33
i have a question, is the MAP sensor the same as the MAF sensor?
RE: code 22,23,33
MAF=airflow [Mass Air Flow]
MAP=airpressure(vacuum) [Manifold Absolute Pressure]
They take measurements at different places...
