code 25 and 32
Old Dec 5, 2012 | 03:57 PM
cadaver666's Avatar
cadaver666 is an unknown quantity at this point
Angry code 25 and 32
ok so a few months ago my check engine light came on, paper clipped it and pulled a code 25 and 32, egr valve and a faulty air temp sensor, I replaced both sensors and this fixxed the problem. now its pulling the same exact codes again. does anyone have any idea why my egr valve would go out so quick and why does it cause the air temp sensor to jack up. also I have a rough idle and hesitation in acceleration, effects of the bad egr valve? thanks in advance for the help
Old Dec 7, 2012 | 05:49 PM
ohsofly's Avatar
Why did you replace the egr and sensor? When you took off the old egr, did you clean all the crud out of the hole where it bolts on? Im sure the new one is just jammed up... Could have just cleaned the old one.
Old Dec 11, 2012 | 11:27 AM
cadaver666's Avatar
yeah, I replaced it before I became aware that they could be cleaned, next time ill do alittle more research, but my main question about this is why would both sensore trip and the same time? crossed wire possibly? or are they some how connected?
optimus485
May 12, 2012 07:07 PM
92s10Blzr
Dec 7, 2009 03:12 PM
98blazr
44
Aug 21, 2009 01:17 AM
lostatsea85
Jun 30, 2008 10:06 PM
lostatsea85
Jun 23, 2008 02:44 PM
