? on coils
Old Apr 23, 2011 | 05:42 PM
chadillac85's Avatar
chadillac85 is on a distinguished road
Default ? on coils
can a coil on a 93 blazer 4.3 cpi have an internal problem and cause constant voltage to go threw tach wire to make a computer think its at 9999 rpms?
Old Apr 24, 2011 | 06:48 AM
Magmotor's Avatar
Magmotor is on a distinguished road
the white wire on your coil is your tach wire, it goes to pin #4 at the back of yur cluster, check it for connetions, melted or grounding out or whatever.. if the coil had an internal problem your engine wouldn't start or would run like crap for a while & then quit altogether, coils are fairly cheep, $20 at AutoZone, after 18yrs it might could use a new one...if a new coil doesn't work then the cluster is no good and there's no fix for it.....
Old Apr 24, 2011 | 07:28 PM
ok thanks i dont have factory tach getting reading threw datastream. the coils sparking properly.
mikeinwi
Jun 30, 2008 07:31 PM
guitarman
Lowering Tech
Mar 16, 2008 10:54 PM
stiltz1634
Suspension Tech
Mar 24, 2007 04:27 AM
CashSax
Feb 3, 2007 06:07 PM
BlaZeR FXB1581
Suspension Tech
Apr 3, 2006 02:52 PM
