COMPLICATED 4wd problem need help asap
Old May 16, 2011 | 08:16 PM
true serus0's Avatar
true serus0 is on a distinguished road
Unhappy COMPLICATED 4wd problem need help asap
ok so kinda lengthly but i need help quick about 3 weeks ago i noticed the lights on my 89 s10 Tahoe for the 2wd annnddd the 4wd low were on i tried everything in manual to disengage nothing worked took to shop they said bad sensor 3 days later i noticed a sqeeling then today loud screeching and grinding pulled over and entire driver side wheel and front end is covered in front end dope worried i may have blown out the front end and still screeching and grinding horrible so 2 part question one how can i get it to disengage from 2wd and 4wdlow all i want is 2wd 2 anyway to simply repair the damage done without replaceing entire front end please help quickly
Old May 16, 2011 | 09:40 PM
Do you have push button 4wd or a lever on the floor?
If you have a green grease on the front driver wheel, you likely blew a CV joint and need to replace that CV axle. The CV axle always turns regardless of transfer case mode.
Old May 17, 2011 | 03:33 AM
Default i have a lever i beleive
there is a gear shifter in the botttem of floor that says 2wd 4 hi and 4 low with lights on itn and the 4 low and 2wd are both slightly lite up and there isn't anything green just alot of what looks like oil
Old May 17, 2011 | 06:37 AM
If you have a manual lever on the floor, then the transfer case is not in both gears at the same time. The lights work off of the lever position. Something has to be wrong with the switches in the floor console that trigger the lights. I think you have two separate issues, one that is very problematic (the grease at the front wheel) and the other that is just an annoyance.
Old May 17, 2011 | 05:58 PM
Default ok
ok well i believe i solved where the oil/grease is comming from it seems i blew a oil cooler line ... though not sure what caused it and it leeked down onto everything i pulled the front wheel drive shaft this morning and drove to work that seems to have stopped the noise aka grinding and screeching also not sure what caused noise only that it stopped when shaft was removed
Robt77
May 3, 2014 12:50 PM
Iomega0318
Mar 22, 2012 02:03 PM
wallacereid
Jan 9, 2012 12:34 PM
smg614
Jun 21, 2011 12:13 PM
cartunez2004
14
Sep 25, 2009 10:31 PM
