Compression Test 1993 Chevy Blazer
Hello, does anyone know what the compression should be for a 1993 Chevy Blazer? V6, Vortec, 4.2 ltr...
Thanx
Thanx
I found this in an old thread:
__________________________________________________ _____________
From the GM service manual:
Minimum compression recorded in any one cylinder should not be less than 70 percent of highest cylinder. No cylinder should read less than 100 psi. There example is if the highest cylinder reads 150 psi the minimum allowable at 70% would bre 105 psi.
The recommended proceedure is to remove all spark plugs, block the throttle plate wide open, disable the ignition system, zero the compression gage, crank the engine through four compression strokes. check all cylinders in the same manner. If a cylinder registers low compression, add one tablespoon of motor oil to that cylinder through the spark plug hole and re-check compression.
Ain't the 'search' function grand?
thanx for the info, may i ask what you typed in for the search...i googled yesterday and found lots of sites that had the word compression in it but nothing that actually gave the psi..and i'm assuming that what's recommended is standard for all blazers?
thanx again
thanx again
oh yeah, the engine is a 4.3L
rogerf1970
03-27-2013 09:00 PM
jimnva
06-27-2011 11:36 PM
bigdaddykane93
01-23-2010 02:10 PM
kerander
02-08-2008 02:49 AM
m00nwater
02-27-2006 01:34 PM
