Cure time
Old Mar 31, 2008 | 08:57 PM
badwrench's Avatar
badwrench is an unknown quantity at this point
Default Cure time
Have 92 4.3 I had to do R&R the intake on--how long after I put theRTV in the valley pan before I can start the eng?
Thanks
Old Mar 31, 2008 | 10:58 PM
Zygoat's Avatar
Zygoat is an unknown quantity at this point
Default RE: Cure time
lots of people say at least 24 hours.
Old Mar 31, 2008 | 11:28 PM
Should say right on the side of the tube. Manufacturers specs should be followed for the best results. 24 hours is a good rule of thumb!
I just replaced a transmission pan gasket on my aunt & uncles '02 Stratus because some "smart" mechanic decided to use 2 tubes of Ultra Black on the pan (definitely more than 1 tube and I am NOT exagerating) and then fill it with trans fluid. There was even RTV on the valve body! This was over a 8 months ago and in the big globs, the RTV wasn't fully cured. Moral of the story, if you are going to use RTV, make sure that the surfaces are VERY clean, only use the amount required, and allow time to cure before putting the parts into service!
pettyfog
Feb 22, 2012 12:49 PM
Cee-Jay
Tires and Wheels
Nov 5, 2011 04:00 PM
Dan 128
Jun 10, 2011 11:58 PM
ddog800
14
Feb 16, 2011 03:01 PM
paulbaby
Aug 19, 2008 08:28 PM
