defroster/air conditioning question
94 s10 blazer. Does the defroster require a/c to function. My a/c is empty and I do not plan on converting and refilling. When I turn the defroster on, a/c clutch clicks on and off like crazy. Their are two separate wires connections I see at the compressor. Can I just unplug them both to stop compressor? Will defroster will function? will disconnecting send off any cel?
i doubt you will get a cel if the ac is not working. the ac works with defrost to get the humidity out of the air before it blows on your windshield and fogs it.
if you disable it i dont think it will make a diff. the clutch on the compressor should stay in the "neutral" (wrong term maybe) as if the ac was off anyway.
DCFluX
05-16-2008 09:20 PM
KaptainKen
03-23-2008 05:03 PM
